The rocket Typhoon
jjorgensen52
NHSTE - I'm the only one!
Some of you guys might remember a while back when I posted some pics of the Ty with the rocket shaped intake. Just got a little update on the truck, thought I'd show you guys the pics. Was running a VGT (variable geomerty turbine) turbo, put was having some difficulties tuning due to high boost levels (25 - 30 psi ) and the relative difficulties of working with the VGT, which ended up being too small. The truck was forced into being daily driven recently, which was bad considering the state of the tune.
To quote:
"So I fueled it to the max (<11:1) and kept advancing the timing until the boost stayed down to around 25-28 psi sustained. Unfortunately at this level of timing (around 18 deg at 6,000 rpm and 28 psi on 91 octane)"
In any event, it blew headgaskets. Now in process of being put back together and swapping to a GT35-R (truck is already a built short block, Brodix heads and a custom sheetmetal intake w/ 75mm TB )
Driver's gasket
Passenger's side
Approximate power and torque numbers based one acceleration and 20% drivetrain loss
(second gear has higher power because 1st gear limited boost to about 18psi, while 2nd was running right up to 28 psi)
H-TOWN-TYPHOON
You're killin' me, Smalls
Re: The rocket Typhoon
So is he getting rid of the rocket intake?
viperman5
VGT turbo? Is that the turbo they are putting in the new 997 Turbo? The vanes in the exhaust housing turn so it spools quick then opens up to allow exhaust flow.
jjorgensen52
It is the same kind of turbo that the new 997 has, although I believe this one was originally intended for a diesel (hence why it makes so much boost). It was to the point when he first installed it that the truck was undriveable because it kept hitting the boost cutout ;)
Mike, the only pic I have if it is the engine bay pic of the intake ( here ) but it's not really very good. I do not know what he's doing with the turbo. I do know the rocket intake isn't leaving though :lol:
