Lynn D. Brown
I just did some more digging on the GMPP website, since the stock OilPan won't fit my Bowtie 4-Bolt Main Cap block # 10185051. John of Winded V6 had McCoy do his Bowtie, and it did fit.
Well it turns out that Johns' block was the 25534333 block and this block is identical to the 5051 except it has Nodular Cast 4-Bolt Caps, which must be smaller. The 5051 block has 8620 Steel billet caps, which should be stronger. If I would have known that, I would have gotten the Nodulars to avoid these Oil Pan Mods, or Mike Lees' Aluminum Oilpan. I'm not sure it's worth switching Caps at this point.
I also got some prices on the Cylinder Heads offered there from Dal, as follows
# 10134359 18 Deg Bowtie Heads - $630.
# 12480009 - Same Heads in Alum. - $621. (not sure this makes sense)
# 10134394 Splayed Valve Heads - $1297.
