The Ultimate Betrayal
TYTILIDIE
METH HEAD
So I took my crank to the machine shop today to have it checked out and they seemed to think it looked ok. I had found a groove on #1 main journal last ngith and showed it to them. They didnt seem to think it would be a prob. I got a little weary. I had them re-do the crank for me, I picked it up at lunch and they didnt seem to have much to say. I was starting to get the feeling that htey knew something and didnt want to tell me. So I took it over to another machine shop for a 2nd op. They said the rod journals were tappered by .010. So I wasnt really sure I trusted the guy as I have done business with my shop for over 7 years. So I took it to guy who builds race motors and is very honest. He took the time and measured each side of every journal and looked at me and said..." I would nt run this thing in a ****in go-cart race". He told every main journal was a different size. Same for rods. He showed me how it looked like they had jsut polished it jsut to make it look good so I wouldnt notice anything and would think its all peaches. Anyway, Im not sure what Im going to do now. My trust is completely shaken in these machine shops now. I think Im going to let this guy take care of me though this time and see how it goes. Hes wanting $100 to grind the crank and $45 for a new set of bearings. I have a friend who uses this guy and he has a very good rep around town. Its too bad my machine shop dicked me cause Ive done a lot of business there. Oh well, win some lose some.
Mike
cloneman315
Re: The Ultimate Betrayal
seems likes there is a lot of horror storys lateley about machine shops,hope mine works out
GarnetTy1473
Even the shops that have taken care of you before, will sometimes screw you in the long run. There is a particular shop in Indy, that built a motor or 3 for us. We used to always build our own motors, but gettin down the 9.0s, started lettin other do it. Well, this shop hooked us up with a good deal if we put his name on the side. No prob. First motor ran good for bout half a season, then elec problem, it didn't shift into 2nd. Bounced is off the rev limiter, and broke the top off a valve. Not a big deal, put the motor we built back in. Same motor, but different cam, and ran 9.50s. Had the heads redone, and good to go. While the heads were getting redone, the weld on the oil pickup in the motor we built, which we ran for 2 years without a problem broke off during a run. Burned up the bearings on that crank. So, our motor goes out. In the meantime, we got our heads back, and while he was at it we had him go through the block again. Put his motor back in. 2nd run down the track, oil pickup falls off. No welds broken, he just didn't put long enough bolts in the pickup, and they backed out. Luckily, it was in the pits. No damage done, except cost of entry fees. Then, wait, as I'm writing this, I'm forgetting the order that all this happened. To make it short, in 1 year, 3 major motor problems all related to that shop. 2 times too short of bolts in the oil pickup and it fell off. 3rd time, don't know exactly what happened because it destroyed so much it was too hard to tell. But it looked like a rocker was hitting the valve spring retainer, dropped #5 valve. Bottom went through the piston, top went up the intake and down #8, breaking that valve and destroying that cyliner. Pics of that breakage is on our website in my sig. 2004 pictures. All that they offered to rectify their screw up, was $400 off our next rebuild. Which is what we spent on wasted entry fees each time the motor broke. Can't trust em all. We found a few better shops now, more expensive, but no problems yet.
bigtime
Sy-Ty Builder
Since I guessed the problem can you PM or email me the shop that did that to you? I have a friend in Fowler CO that is looking to get some work done and want to make sure he doesn't go there. Thanks, Bob
TYTILIDIE
METH HEAD
Fowler is outside of Pueblo. Is he coming up to the springs? Lee's Machine is the one that this happened with. McCabe Motorsports is the one I am currently going to. He is more expensive than most but does a lot business. He is more on the racing side of things. Hope this helps. If your friend needs anything while he is here let me know. I am always willing to help out.
Mike
bigtime
Sy-Ty Builder
Thanks, It's a shame people don't do good work, good luck. You do know that the crank is the same as any 4.3 so you can get another one from any crankshop. I would't want my crank .020 and .030.
TYTILIDIE
METH HEAD
I was told the crank had a different balance. The guy I had it to yesturday showed me one of his 4.3 cranks and the weights were different. Same pattern for the rods though. H e also showed me that htere were different cxasting #'s. He found me one today but I cant afford it unfortunately. I have decided to have this one worked over again by someone else. I had another op today and the guy agreed with the guy from yesturday. However, He said that the #2 rod was way under what it should be and that if werent for that he would say to just do a real good polish or wouldnt have to do much grinding. I agreed to just take it down to .040 and .020 . If it ****in snaps it snaps I dont really give a shit at this pouint. I have to be out of my house by the end of the weekend and I havent even started moving yet. Im not going to have a garage where I am going and it will be atleast 6 months before I do so I just want to get it running at thhis point so Im not moving it in pieces. If I have to put it in storage then oh well I guess. I am prepared for the worst right now. The guy I talked to today told me the oil cooler cant be cleaned out, is this true? I am thinking of bypassing it. I cant imagine it makes much difference anyway. My Vette didnt have one and I had a lot of goodies in that motor and never had problemns even after 100,000 on it.
Mike
bezerk
i'am sorry to hear this..
that freaking sucks............
i brought the engine to an other work shop yesterday, and the also have a tractor puller which run 2K HP!
they only build high HP engines for US brands, and i really hope they do a good job!
good luck with your build..
berzerker
wookie
good luck with everything . hey when u get ready for some vortecs and mod the lower intake ,give me a pm i hook you up with a shop that will do it for you cheap .there up in denver . to give you an idea i paid around $500 for intake mod ,772 head castings / trade lb4 junkers for cores, fully rebuilt heads w/ 2.02 - 1.60 .
TYTILIDIE
METH HEAD
Holy crap that sounds like a damn good deal. Who did this for you? Hove you run it yet? If so how has it held up?
Mike
berzerker
wookie
everything going good so far with build . had a little bad luck with a broken rocker stud last week . still tuning with cheathams help . only running 16 - 17 lbs of boost with 91 oct. and little or no knock even with 150 deg . intake temps on the hot days . working out a few bugs and hoping to get a good tune and turn boost up to around 22-25 lbs soon !!! when your ready to convert over to vortecs let me know .
TYTILIDIE
METH HEAD
I will definately keep that in mind. I have been quite curious about that lately. Thaks Ill keep in touch for sure.
Mike
