the ULTIMATE Question "problem"
Pittman
Ok this truck is about to kick my ass. I have the ultimate chip, hipres fuel pump, regulator. The truck runs great on everything except "T2-17". All the T1's work and run all the other T2's work well. Havent tried any of the T3's under boost or even at wot and really dont think I should. Ive tested all T1 with 93 and 105 and the T2's with 105. Everthing is great except t2-17:( what the hell? All vaccuum line were checked a few replaced just in case. The throttle position indicator was checked and replaced to solve a 200 rpm oscillation at idle fixed that. Ignition was checked timming good. Boost control is solid under 18psi. Took ultimate out and ran stock and runs good. Then broke the nipple off the stock map sensor so I cant do that test again.
Anyone have any ideas?
Also off the subject how much boost is the stock turbo able to put out at WOT as your running down the 1/4 or floored on the highway. I was wondering if 18 is the limit that the stock turbo will put out continously. They dont appear to have a whole lot of cfm by the size of the intake snail.
The stock turbo is rated around 550 cfm and can make 30 psi if you wanted it too, don't ask me how I know :smile:
Maybe that bin is messed up and the rest are ok? I'm not sure how it works but I beleive that could happen. Maybe Brian will let us know.
smeagol
It could be a hardware problem if only one program isn't working. There's a slight chance that the eprom isn't burned correctly, but I really doubt that on the stock injector programs. I haven't messed with those in a while...the 50s... I tool with those too often :wink:
Email Todd & I about this, the exact symptoms etc, since Todd doesn't read the board much or at all.
syclone160@yahoo.com - me
Todd.A.Austinson@grc.nasa.gov - Todd
Pittman
Yeah I just emailed him back Im going to FedEx the chip to him so he can check it out and send it back
Pittman
By the way I would like to mention that Todd Austinson has been a big help and is sending another unit to try to trouble shoot this. He answers emails, calls and ALL questions promptly. I wish all people were as good to work with.
Thanks
Todd
I like the nasa email address too, I guess getting a sy to run good really is Rocket Science
ty1on
can a chip or the stg ultimate go bad? changing programs does nothing, i use t-1 15, been fighting this full trottle hesitation for days, when truck is cold runs fine, feels like it is in valet mode rev limit cuts out at 3500!!?? also, i thought with the ultimate it turns on the ic pump full time, i had to jump the yellow wire in order for it to come on!! any ideas?? thanks, tried new plugs 35gap, cap, rotor, adjusted fuel pressure from 60 to 50, used fuel injction cleaner, timing is 0, vacucm lines are fine, bought truck it had no cat. ran no problems wot, put cat back can not get wot!! checked cat. sems to fine,
smeagol
Sure things can go wrong, and the Ultimate could go bad if it is handled roughly, or if the cable is pinched/shorted.
Before you blame a chip though, make sure it is a chip issue.
Do your problems clear up with the stock chip and 2 bar map sensor?
Did the Ultimate run fine for a while, now it's having problems?
Give us some background.
Does it have any codes set?
Does a scan tool read out the Program ID's?
Do you have a stock chip piggybacked to the Ultimate?
_________________
Brian Green
www.chitownsyty.com
<font size=-1>[ This Message was edited by: Stanley Spadowski on 2002-03-08 06:59 ]</font>
Pittman
>no
>thats what Im doing
>Yes with the stock chip also
>No
>My garage is white with grey floor
>no
>you mean prom ID's?
>yes chip piggybacked, although its the hypertech chip, shouldnt cause any probs though
the truck runs GREAT everywhere except t217. All vac lines run and done. All sensors that were questionable, replaced.
smeagol
The questions were more for ty1on, since I assumed that you and Todd have been working over your problems in emails... is that the case?
Pittman
Yeah it is your right, It was a long night and just had to answer it. I was in an Oh hell type I guess.
I thought I could make those points clear to other readers.
Where do you guys get the Simpson pictures? and how do you get them up on your signature?
ty1on
when i bought the truck was told the ultimate would not work properly without a cat. on it, it would spool up really fast with no hesitation, fuel pressure was set to 60, put cat. on lowered fuel pressure to 50, started to hesitate at about 3000 to 3500 also wot it would happen, with pressure at 60 with cat. plugs where slightly black, tried 50 cleared the plugs up but have hesitate at 3000to3500, if i eased into it would acccerate without any problems, do not have a scantool or laptop yet, looking for one, just missed one on e-bay! ic pump would not turn on so jumped now it is on, should the ultimate have done this anyhow?, no do not have 2bar to switch back to, how would i check if it piggy-backed? thanks
_________________
40 ford 2dr sedan streetrod [family sedan]
41 ford p/u streetrod 12sec 1/4mile 106mph
92 ty 13.28sec 1/4 mile 99mph
95 buell s/2 thunderbolt currently for sale
<font size=-1>[ This Message was edited by: ty1on on 2002-03-10 23:49 ]</font>
smeagol
Describe the hesitation at 3500 RPM. Does the tach flutter?
Piggyback - you'd have to drop the ECM from under the dash and see how the chip is installed.
ty1on
when it gets to the 3000, if i let off alittle i can get past the stumble, its not a cylinder cutting out feeling, tach is fluttering as this stumble is happening, upped the fuelpressure today, did it only slightly once, could be all this freaky nj weather, 60 one day 15 the next!!
