The Verdict is in
TYTILIDIE
METH HEAD
Well, my motor is trashed. I found several things broken inside when I pulled it out today(with help from Jeff and Austin of course). First thing, god damn pick up tube weld broke all the way around and pick up tube fell off :rant: . This was the cause of my last failure except that the tube was not welded on last time :roll: This time I will be getting a different tube that has a brace. Second thing I found was the many of the bearing on the rods were wearing down pretty bad. Finally, I found three pistons with broken top rings. At first I thought I really need to get this back together with all my new goodies but then thought about it. I think I am going to take my time with this one and do a nice build up. I'm planning things like custom cam, possibly 2 piece timing cover, four bolt splayed caps, fluid damper. The "little" things that make a huge difference in quality and cost a small fortune you know? I already have vortecs ready to run, turbo/DP set up ready to go as well. It looks like I may be looking at early spring before I am back on the road again. This is going to suck.
TYTILIDIE
METH HEAD
Re: The Verdict is in
jpalmer said:
good. are you going to do a write up on it in member projects?
I wasn't planning on it. It seems these things are kind of common knowledge around here these days. I can if people want me to though.
jpalmer
the only thing is it does take time away from putting it together, and i dont think you need motivation, so maybe not
