SeattleSy#1255
Category 5 Conservative
I'm still learning about builds so excuse this thread if they are bonehead questions.
I know a lot of this depends on your goals, but i'm only talking strength, reliability, and power allowance.
1) is the weakest point of a bottom end the rods, no matter what you are using?
2) what is a properly treated stock crank worth HP wise 600-700?
3) if a build went: stock (treated) crank, Oliver Rods, and JE pistons is my weakest point now my crank and would it be worth going with a billet crank sice you have excellent rods and pistons.
4) using a stock treated crank, are you waisting money going with rods that are more expensive such as Oliver over Eagle and pistons, such as JE over SRP?
5) Basically i'm wondering what the weakest point is to a bottom end and maybe with a 15-20% increase in crank strength, is a billet crank worth it over a stock treated crank.
6) what is a safe HP range for a stock block?
Thanks for info...i'd like to plan things out, but need to start somewhere.
