Looked at 2 (#1 and #5) plugs the other day just for the heck of it. To me they seem lean. Half way around white, “normal” brown the rest with a little splotch of black. Plugs are AC Delco CR42TS. Truck has stock FP, FPR, turbo, IC (except the pump’s full time).
The symptom: Fuel pressure rises more than 1 lb for each lb of boost. For example at idle I’ve got 40psi at 14 lbs (aprox) of boost I’ve got nearly 60 lbs.
The theory: What I’m wondering is if my injectors might be flowing incorrectly, as in lean. In other words if the injectors are flowing less than spec. then a.) I’m lean, and, b.) fuel pressure is high because the engine is using less than the correct amount of fuel under boost. Make any sense? Does my theory fly or is it pie-in-the-sky?
BTW I just got a set of 40 lb'ers. 3 years old but still new in the box. Because of the small difference in flow can they be used or do I have to reprogram the chip which I have coming.
Thanks,
Thanks,
