these the right ones???
Raist103
for ty with vortecs?
Make: CHEVROLET
Model: S10 BLAZER
Year: 1997
Engine: V6 - 4.3 -
= ultimate class
= premium class
= super class
= regular class
NGK: IX iridium tr55ix
14mm, .708"(18mm) reach, 5/8" hex, tapered seat, resistor, projected tip, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode, .059"gap
NGK iridium plugs represent the ultimate evolution of spark plug technology and performance. The iridium center electrode is both stronger and harder than platinum. This allows NGK engineers to design an ultra-fine (0.6mm)center electrode reducing the voltage requirement for spark. This allows for a brighter, stronger spark from your existing ignition system. The ground electrode has a tapered cut at the firing end which reduces quenching for better flame core growth and increased ignitability. The combination of fine wire center electrode and tapered cut ground will increase performance, improve acceleration, and fuel efficiency.
Ty0279
Historically Significant
Compliments of Hood:
Vortecs
AC Delco - R42LTS
NGK - TR5 (stock heat range)
NGK - TR55 (one step colder)
NGK - TR6 (coldest)
Autolite - 764 (comparable to TR5)
Autolite - 605 (comparable to TR55)
Autolite - 103 (comparable to TR6)
Raist103
yeah tried most of them but these are new, just out maybe 1 month maybe 2. 104s working ok just wanted to step it up a bit.
thanks
