Thinking about ditching the peashooter
sae
Re: Thinking about ditching the peashooter
That's the exact turbo I was looking at, I emailed them asking about a 9 blade for the td06h 60-1 because it wasn't listed at the time, so they added that drop down option recently. I'm hoping to order it and put it in before summer's over. I talked to a few who said that the 9 blade would spool pretty close to stock, so Id assume a 2800 would be good.
It's just a six
Super Member
If you use a 8 CM turbine housing, 2800 would be too much stall & not really needed IMO.
If you choose the 10 CM, I would not go higher than 2600-2800 Max stall.
I like the specs on that turbo, I just don't know anyone using one right now.
Hope to see some feedback whenever someone does get one though.
I thought you can as an option of different wastegate pressures also?
