This might be a dumb ? but..
spooldup
Super Member
Say you run the stock turbo at 15lbs and then you run a bigger turbo at 15lbs. Wich one is faster or makes more hp, or are they the same? Like i said probably a dumb question but on my ty i have a bigger turbo and it's set at 15lbs.
Buster
A bigger turbo should make more power, but you'll give up some spool up, so I wouldn'd expect any gain in ET, but you should see some in the Mph.
Tooky
Serious about performance
The way I understand it, it's pressure and volume. The bigger turbo undoubtebly flows more CFM (air). Pressure is the same (15 PSI) but volume has increased. Add more fuel to accompany the additional air, and now the motor is producing more power.
Buster
Don't think so. If you add more volume you add more boost, boost is just back pressure on the heads. I understand the benefits of a bigger exhaust housing and bigger turbine, but don't totally understand the compressor side, it's a question for the gods to answer.
damianhol
Isn't psi read by the MAP sensor? It's not the pressure within the turbo being measured. If it were, then a larger turbo at the same psi would push more air. So a bigger turbo with less internal pressure and a smaller turbo with more internal pressure can push the same amount of air to result in the same psi as read by the MAP sensor.
Tooky
Well Mark, I don't beleive in god but I do have another theory why bigger turbos can make more power. They create less friction on the air they are compressing since they don't have to spin as fast to generate the same amount of boost that a smaller turbo would, and as we know, colder denser air makes more power than hot air.
smeagol
Compressor side - basically the 'big' turbos won't heat up the air as much when they produce the same compressed air at the manifold. So you have the same air pressure, same volume (manifold), so the amount of air has to change (n). So *more* air makes it into the engine. Combine this fact with a more efficient (less backpressure) exhaust side, and you can see how the 'big' turbos can make more power pretty easily, but at the expense of response.
Also, a turbo like the stocker is very inefficient at higher boost levels, basically heating the air up too much as it compresses it. The larger turbos (generalizing here) can achieve higher pressure ratios without heating the air up too much.
If you look at some compressor maps you can understand this better, as the stocker has very poor efficiency past 14psi (the charge air temp increases greatly as you run > 14psi), and the larger turbos, say a TE63 or so, can run peak efficiency to at least 20psi, and still decent past that (on the right motor).
Buster
I was referring to the syty gods.
Mark L
Tooky
So what do you need to do if you want to run Big Boost? It sounds like you would need a dump truck turbo in order to remain efficient.
Tooky
Well when we hear the stories of the guys going really fast it sounds like they are running 24+ PSI, at least that's the impression I get.
smeagol
There are some turbos that are efficient in that range, and also, most of the bigger turbos' efficiency range doesn't drop off nearly as fast as some of the smaller trucks. So you might have 65% efficiency at 25-30psi, which would still give you more airflow, without heating up the air excessively.
Another thing to consider is that a compressor map is rated for pressure ratio, so if you have atmospheric pressure at the inlet and 15psi at the outlet, it is the same ratio as running 1-3psi at the inlet, and 17-20psi (didn't do the math here) at the outlet of the turbo. When could you have such an occurrence? Ram air systems - look at Duttweiler's red Buick. Inlets are RIGHT in the hood. Tell me those don't have 5-10psi of pressure at the inlet of the turbo (at least). Tractor setups use staged turbos, with turbos blowing thru each other. Setups like these can work to achieve very high manifold pressures with high efficiency.
