those with alky/meth /water
Gnocide
turbo game burt reynolds
i was wondering where its hooked up to inject
also where did you mount the reservoir?
i just acquired an old school smc kit with pump in the bottle that im putting on .
pics of your engine would be great to show the mounting
Ross L
Re: those with alky/meth /water
not that this helps much... but. I have a stock upper and it was drilled on the outlet(lower lip). Alky is incredible! I run 24 psi with 26 degree's of timing on my GN... 0.0 knock retard. Hey, I told you this post wouldn't help much :rotf:
Ross
I mounted the reservoir where the rad header tank normally goes. The nozzle is at the bottom of the outlet from the IC. Required a small notch in the hose to the TB.
Do some searching, there are pics of various installs here.
Gnocide said:
has anyone used the upper intake vac ports ?
Probably a bad idea as the distribution to each cylinder will suffer greatly.
