HAMMERHEAD
I have been trying to find the source of my idle/ stalling problem for about two years. The truck dies sometimes when you put it in gear. Occasionally shuts off for no apparent reason when idling and sometimes idles at 2k and eventually comes down.
As far as performance it runs great. I have changed ignition module, all vacuum lines,computer, computer chip,iac and nothing seems to help. I even put the original chip and 2 bar back in and no luck. I have good vacuum. Around 20-21 at idle and 18 in gear.
I decided to change the 3 bar map sensor since that is the only thing I did not ever change. I ordered a cheap 3bar gm one off ebay and installed it yesterday. When I started it up, it idled immediately at around 800 and and about 600 in gear. I was idling the best it has ever been. It idled with no stumble and it was so smooth and then I noticed that my a/f ratio was in the 9's instead of the 14's like usual.
It is idling pig rich and now check engine light from being too rich. I don't know if I got a bad sensor out of the box or what. Anyone got any ideas.
