Really scratching my head on the nozzle location. Haven't done it yet but thinking of the bottom of the IC, TB side, on the little 45 degree area between the where the hose goes and the flat bottom. This would aim the nozzle back toward the actual IC and into the air flow. My thinking is that, when spraying, there is so much air flow the alky won't hit the IC and all should be well. And even if it did hit the IC I don't think it would matter much.
Thoughts?
Second Q; once installed what do I pour into this thing. Single malt, Jack Daniels, what? Seriously, I've been kinda lookin and haven't found anything. You'd think the directions would say but noooo...
Pump location. Since I usually leave out the pas wheel well (takes some of the work out of a plug check) I'm thinking of the shelf behind and under the headlight? It'll just fit if I modify the plumbing a tad.
Thoughts?
