Throttle Bodies
TurboJunk
questionable
Which throttl body is the equiviliant to the SYTY one? i have a brand nw LT1 style TB with air foil and im curious to knwo if i can use it or an i wasteing time?
jwaller
Evil Genius/SyTy Guru
Re: Throttle Bodies
it will probably bolt on, but you need to make sure to swap out the ramps for the TV cable. the one on the syty is very specific to get the TV up and going asap to help the tranny out.
TurboJunk
questionable
Re: Throttle Bodies
thank you a lot. actually i have another question mr jwaller since your the SYTY guru... my truck is a 1992 2wd jimmy(3580lbs w/ driver) with a 93 TY motor. i have ty rear end 2100 stall converter. everything i bone stock. wit no intercooler (cause i was expecting to get my front mount finished ALOT sooner) all i have is the upper piece by the throttl body. at the track it had horrible 60' times cause of wheel hop. i could only leave at 0 on the boost gauge.
RT-.187, 60'- 2.34, et 14.10 @ 99.62mph.
Now i have installed caltracs, relocated the battery to the back finished the front mount and custom cold air, egr deleted, fuel pressure at 40psi, 255 walbro, stock computer chip (want to buy ultimate if anyone has a used one), Grand National electric fan, no cat 3" borla catback, 180 thermostat, external wategate.... EVERYTHING else is stock. what are your predictions for ET's? and what advise could you give me on upgrades for the future?
Re: Throttle Bodies
The SyTy TB is a 89-92 TPI style. I am not sure about the differences, but they are different part number.
