throttle body gasket blowing off
Sean Donn
has anybody had an issue with their rubber throttle body gasket (connects to intercooler with two clamps) blowing off while accelerating? if so, how did you fix it?
Chest Rockwell
Re: throttle body gasket blowing off
Still got all three brackets holding the intercooler on? Assuming it's a stock intercooler, and not a/a.
jaystcb
Sy 0902, 92Ty 0909
I had that problem, I changed out the hose clamps to new ones, readjusted and tightened down the innercooler brackets. Then I started blowing off the pipe from the turbo to the innercooler. So I Changed out the hose and put new clamps on that one too. Haven't had a problem sence. Might want to think about adding a blow off valve if you are still having problems after the repair.
Tony Dipatri
Happened to me also. Intercooler was loose.. I tightened the intercooler down, degreased the the inside of the hose thats connects the two and tightened down with new hose clamps
