Throttle Body Shaft Removal
werbicki
<User Title Goes Here>
Does anyone know how you remove the shaft in the throttle body? Reason is I'm sending my TB away for rebuilding but I want to bead blast all the pieces before I do and I can't get in there with the shaft still in place.
I have the airfoils off but there isn't any screw to disconnect the linkage from the shaft. I was thinking that I need to grind/drill off the rivet on the linkage side? I'm assuming that the rebuilder would have to do it anyway and they'll tap the shaft and put a screw back in.
Any help would be great!
Paul
4C FED
Absolutum Dominium
Re: Throttle Body Shaft Removal
You have to grind off the swaged end of the shaft on the linkage side flush with the linkage.
Then linkage will then come off. There is a small round aluminum cap that is knurled inside that is pressed onto the body. Use a screwdriver to pry it off.
Then remove the screws that hold the butterflies to the shaft. Use a fine file to smooth the shaft where the screws past through otherwise it will be difficult to remove and further gouge the heck out of the bore it rides in.
There could be a detail or 2 more that I'm forgetting, but that pretty much covers it.
werbicki
That's kinda what I figured. I assume that "swaged end" means that little bump of metal on the linkage end in line withe the shaft that I'm calling a rivet? I already ran into the fun with knurled end of the screws holding the butterflies on. :tdown:
BTW, do you know if the aluminum in the stock TB is cast. I'm thinking of getting it anodized red but apparently cast aluminum doesn't come out very nice.
Paul
4C FED
Absolutum Dominium
Yes, that bump that your refer to is where they smash the end of the shaft to hold all of the linkage on.
I'm pretty sure it is cast. Why not powdercoat it. Anodizing will eventually fade unless it is hard anodized which will cost more.
The guy on EBAY, Matt Blum will rebuild (increase butterfly size if you desire) & powdercoat it for a reasonable price.
werbicki
Yeah, we've been talking, I'm planning on going for the 52mm inreased size. I didn't know that he powdercoats too, but I should have guessed considering the powdercoated TB plates he makes. I just want it to look like new, powdercoated or anodized!
Thanks for the help!
Paul
4C FED
Absolutum Dominium
He doesn't do the powdercoating himself, he has to send it out. So plan on adding another week to the turnaround time if you decide to have it coated.
