Throttle cable Manufacturer
MoJo
Re: Throttle cable Manufacturer
To answer your question, the 1991-1993 Syclone (ZR9) and Typhoon (Z79) throttle cable is the same part and is exclusive to those vehicles. It is GM-15637756 but as you probably know, it is discontinued...
If your sources fail to produce a throttle cable that fits, try LOKAR ( www.lokar.com ) .
eviltwin
"junkyard syclone"
Why do you need one? I got one off my parts 93 you can have. Pm me if your interested.
vinnieTy
TY # 1889
Thanks Mojo i will look up lokar and see what i find.
Thanks eviltwin for the offer but i would prefer a new one if i can get one. Mine is stretched and that is the reason for me looking around for a replacement.
Aeroking
e.i.
Is the cable itself just a continuous braided line inside the plastic cover? I have barrel ends, and cable crimps. Would i be able to pull the line out of the plastic cover, make a new cable, and feed it back through the plastic cover? Then put a clamp on the pedal side
vinnieTy
TY # 1889
By any chance did someone find a place to purchase the throttle cables? I guess what i will do is remove what i have first and then post up what exactly it is and what i need to replace.
Aeroking thanks for the offer would have said that sooner if i got notified i had replies to this thread.
Thanks
Aeroking
e.i.
I did end up making my own. It wasnt very difficult. And while i was in there, i bent my pedal so i have a full throttle sweep now.
