throttle cable needed
i8av8
looking to buy a throttle cable since mine is unraveling and sticking. thank you. nick
atkonkler
Is this your bush?
Re: throttle cable needed
Contact tom at sportmachines it's worth a shot....maybe lokar does them.good luck in the hunt.
blue83z
I have one from a jimmy. Not sure if they are the same. I could measure it and compare to stock one
i8av8
from what i remember from reading on here is that the lokars are not a direct fit and the s10 and jimmy vehicles are not the same as our trucks.
syty specific i believe
Norm
Make one, Wasn't there a post about somebody who made a bracket that it works with a regular Camaro (?) cable or something along those line.
Norm
I remember meeting a member at the races in Fargo, North Dakota a couple years ago. He made a bracket that bolted to the factory location and modified the holding part of the cable housing. it was from a Camaro or some gm car, was a few years ago so can't remember exactly what it was, but was a cable that gm still made. Wish I still had mine to sell, but sold it to Tom a year ago or so.
Brassmonkey
Cruzin' Mel Man
GM # 15637756 is for the SyTy cable, but GM #10163822 will fit, but a slight modification is needed for the hole in the firewall.
i8av8
I couldn't find anything as far as a camaro mod.
thanks for the thought anyways. nick
i8av8
I will look into this. thank you.
I came across an old thread where warmpancakes listed a dorman part number but going to the site and it says it was down. tried summit racing and the dorman cable looks nothing like it.
almost to the point where i would try a fricken bicycle cable.
IGottaSy
Drive by wire.
wildphil
I Love My Ty's
Lokar cable works great. I put one on my truck. Has the correct ends and you cut it to length.
wildphil
I Love My Ty's
No problem. The ends are correct for out trucks. Cut it to length. Follow the instructions when doing so. It keeps you from screwing up and fraying the strands.
It will fit the bracket just fine. But the hole in the bracket on the intake is square and the fitting on the cable is round. It will tighten down fine. You could put a washer on either side of the bracket so you don't see that the hole is square i you would like. May be a little nicer as far as appearance.
i8av8
you think you could post a pic of it installed?
