Throwing a code
Carnut16
My Typhoon has recently been throwing a code for the IAC. Any thoughts on what could be wrong with it before I take it out? Any tips on what to do or what not to do?
Also, my engine bay has been getting REALLY hot lately. My temp guage hasn't been reading hot, but when I open my hood, the engine bay is hot as hell. This can't be from the IAC can it? Can anyone help me with this? :(
V6 Kompressor
Hi, if that is the code I am thinking about, It usually means that the IAC valve is not responding or the engine rpm is uncontrollable through the IAC valve.... I have seen vacuum leaks, mis adjusted throttle bodies ect. cause this code also... an unplugged IAC will also set a code... Where is your engine idleing at? Does it idle up in the morning (or when started up first) when cold and then come down after it warms up? Carbon also can cause the IAC valve to stick or not close all the way, and finally, yes the valve can go bad... just some of the things to look at...
Ian Turgeon
Cascading Inspiration
connect the top two ports on the rights side of the aldl connector under the dash.
same method to check your codes, if you listen next to the throttle body, the IAC should make a chattering sound when the diagnostic mode is engaged.
Carnut16
When I first start up my truck, it usually idles around 1200 RPM. After it idles for a little bit, the RPM's usually fall to around 900-1000 while in park, but if I put it in drive, the RPM's go down to about 800.
When I bridge the two ports on the ALDL, it does make the "chattering" noise. Does this mean it's something else?
Thanks again for the help you guys are giving me.
