tie down question... where to bolt?
doomdead
Blew out the drivers side motor mount after testing ultimate with roland and richard le (seattle gurus) and after all testing was done and we were done tuning the drivers side mount went out...
thats the stock mount, passenger side is done. drivers side was/is next
so i got a short chain off the alt down to a wratchet tie down ... connected it to the chain and the bolt coming out of the left side of the A-ARM ... there was enough of a bolt there to put the tie down on and put the nut back on.... engine stayed down, all is good...
but when i was backing off that nut, the a rm slipped in about 1/4 in, 1/5 in at the most... then for the rest of the trip home i was paranoid that my alignment was off...
can you guys tell me whats up? did i mess up the alignment? where is the best place to put that tie down....
heres my ms paint 1 min job....
doomdead
ya you went to the back of the bolt on the alt ... i went to the front.
can you give me more of a clue where you hooked it to on the frame. id have to print out that picture and crawl down there
maybe take a pic for me from the wheel well view.
thx
doomdead
nm i spent more than 10 seconds looking at it, and lo and behold i figured it out... ill probably do just that. THANKS
turbodog
Yeah, that bolt has a cam on each end that controls the camber. You need to put it back where it was. If you don't know, look at how the other cam (at upper rear a-arm mount) is, and match that. If you really want to be sure, take it in for an alignment. That's probably not the best place to hook up your tie down....
I used a tailgate cable and hooked it to the bolt where the bumper corner brace bolts to the frame.
doomdead
turnbuckle is about 1 foot at max length... i used a chain (6 links) and the turnbuckel, fron the back of the alt to the same location as SY2932 on the frame.
SY2932
Administrator
Dave,
The turnbuckle is 7 and a 1/8" long. I would not recommend one shorter than that or else it may not have enough "meat" to keep it together :wink: . A bud of mine bought the turnbuckles at a mom and pop hardware store. And I bought the hardware to mount it to the alternator and modified it. His DEFINITELY gets more "abuse" than mine does. One occasion comes to mind in which he lauched his syclone in a parking lot with me riding shotgun. He had an unopened can of pop in the front cup holder and when he launched, the can flew out of the holder and almost struck the rear window :eek: ! We installed ours last year and his is still in one piece. HTH's
Mike Campbell
Sy#26
Upper A arm cam bolts - turning them *both* equally adjusts the camber. Turning them *separately* adjusts the caster - seldom will both cams be in the same relation front to rear.
Get it aligned - you prolly hosed it..... :(
