time for a new motor
syty9933
I finally did my compression test and after testing only 3 cylinders on different sides of the motor , i already have found 2 cylinders with a compression of 60psi, and only one with 140psi. I will test the rest but it is obvious what the status is already.
Anyways right now the truck has 55,000 on the clock and its time for me to keep saving up for a new motor. My dad bought this truck in 92 and it wasnt used much for more than an average car since, i just got my license about a year ago, and there was always somthing that needed to be fixed on it, in a way im glad that i have a good transmission ,body and paint, and that i can start fresh with the engine and know that ive learned my leason about knock. While im working to save up for a new motor, i can do every little thing on the truck that needs to be fixed so that when i have an engine i can have a beautiful and healthy truck i can enjoy and be proud of, and not having problems all of the time on trying to get it running right. Im stuck about where to go with the block. I was thinking about building it all out , but now im leaning towards building a stock engine,votech heads, 415 cam, fmic,3 bar, and pt61 with a good tune, on stock boost. My goal is to have a reliable daily driver that will hit 11s on pump gas. Any input or opinions on how to plan my build?
BoostedSUV
Re: time for a new motor
are your 2 cylinders with only 60lbs next to each other? Could be something as simple as a head gasket..
syty9933
no they are on different sides of the motor, ive heard it knock before and i dont think i would get lucky enough for it to be a head or gasket, even though it dosent run too bad. Is it likley that bad compression on both sides of the motor could be head related?
BoostedSUV
If it was knocking and you heard it that's always trouble... that's a hard lesson learned and a low mileage engine blown up. Sucks dude but good luck... I suggest build a strong stock motor, tuning gets to be expensive and a headache. If I could build mine again I would have left it stock.
Chedarbob90
White Trash Racing
The only way it could be related is if both heads were warped or both gaskets were blown.
syty9933
thanks man, and yea i was thinking about just keeping it mostly stock to save time, money, and because i know alot about the stock setup compared to somthing custom built. With a stock bottom end 11s are easy to reach, and that is good enough for me, and if decide to go for 10s down the road i could go use alky inj. Im thinking about running a datalogging program full time in the truck too
BoostedSUV
windedv6 has a nice set of 4.020 SRP pistons for sale... that would be a good start :tup:
BoostedSUV
haha i saw those too, if i were to use those, would that work with a stock chip? although i would get it tuned obviously
yeah they will work. The block would just have to bored .020 over. You're going to have to take the block to a machine shop anyway so .020 wouldn't be a big deal. SRP are good pistons, that's what I have in my truck.
syty9933
ok cool, so wouldnt it be difficult to tune for , if i bored it and used differnt pistons and rods? or how would i do that?
BoostedSUV
nope, the bottom end wont effect the tune. Heads, cam, injectors will be what effects the tune. Pistons and rods wont change much if anything... They will just be stronger and lighter to reduce rotating weight. Stronger = better and more forgiving than the stock stuff.
syty9933
oh ok, and the same with the bore
BoostedSUV
.020 bore is smaller than a spark plug gap.. it will not effect the tune. If you're planning on vortecs and a cam you will need to change injectors therefore you will need a tune anyway. I say rebuild what you have with SRP pistons, eagle rods, good rings, bearings, gaskets and freshen the heads if needed. Use your block, heads, cam, crank etc. Keep it cheap, simple, and reliable. Tuning will be minimal if needed at all.
syty9933
thanks alot, and what bearings do i need?
syty9933
cool i already, have a pte61, external wg, 3 inch dp, fmic kit and piping, so all i really need is those internals, gaskets, heads, etc... and pull the block get it built and put back in. I think i could get it back on the road in just a couple of months of working :p
