Time slip
Re: Time slip
IMO you didn't pick up 37mph in 2nd half of the track. You would be doing pretty good if you picked up 25mph.
Big Mike
Re: Time slip
Did you data log any of your runs, if you did you may be able to figure you stall speed and top end speed by watching your runs.
wildphil
I Love My Ty's
Re: Time slip
I only logged my third run. But had a intake backfire and lifted. Did get the launch though. Did no further runs until I find out why there was a backfire.
We will have to see what the tune needs. And what I need to learn in driving skills. To get the best safe performance out of my truck. Whatever that may be. I am happy so far. That was the first ever test at a track for my truck and I. I was only running 18lbs of boost. I thought it did pretty well.
Re: Time slip
Just went through his log of the backfire run.
He is leaving at 3600 rpm, 12+ PSI and AFR's are very good through the run.
What I did see is his transmission is shifting WAY to high, the backfire was the ECM hitting rpm limit I suspect. With a 412 cam these motors just will not spin past 5200 without falling fat on their face which I suspect is the problem Phil has right now.
Some shift point adjustments and it will go faster.
