timing chain cover with double roller chain
JuStBlAzIN
i am going with the edelbrock double roller timing chain. do i need to buy a differnt cover or do i use the stock one?
jbone
Re: timing chain cover with double roller chain
whats the difference between the stock and double roller timing chain? How complicated is it to put in and how much? (Sorry if this has been covered before)
myclone
More durable, frees up .0002hp (give or take ;) ), and you'll die of old age before you wear one out unlike the stocker which has a LOT of slop at only 50k miles.
It goes on just like the stock piece and you can pick them up for ~$75 if you shop around.
mrweelr
Part number on this, anyone? I might as well swap my stock one out (72K miles) when I do the aluminum water pump in the near future. Also, is there a nicer timing cover that people have used in place of the stock one (e.g., aluminum, chrome)?
MikeRenz
not stock
plus is makes a great hat:
mrweelr
Anyone have a similar pic of the stocker for comparison purposes?
NecroWolf
lost marbles member
just picture that one half as wide and without the second set of teeth on the gears
