the baPhoon
Just finished buttoning everything up and tried to start it to set my timing yesterday. It would crank but wouldnt fire up, and i found my gasket for my T-stat housing was leaking so i gave up.
Got back out to the truck this afternoon and swapped the dist 180 thinking that would be the issue. Got all the wires back on, and tried to fire it up. It would crank and sound like it was about to run then it felt like the engine was stopping and being spun backwords (i could see the fan blade spin opposite).
Double checked my wire position, checked my timing mark on the balancer, checked my dist again :rant:
I have no clue whats goin on now heh. Left most timing mark is where it should be, rotor is back on 1 after being spun 180 from its last mark.
The only think i can think of is maybe i spun it a 360 accidently but i doubt it.
Ill check again.
Brown wire is disconected, new plugs/wires/rotor/cap.
Ill check again.
