Timing Issues (Last Post Deleted I guess)
SeattleSy#1255
Category 5 Conservative
can't fine my post on the timing issues i've been having...
anyway, i'd like to confirm what i'v done is correct:
1) Remove dissy
2) Remove plug #1, manually turn motor to feel compression and continue to turn till timing mark (left most one looking down) at TDC.
3) Reinstall dissy with rotor facing #1 plug tower on cap
4) Triple check plug wires on right.
5) Attempt to start truck and runs like crap...check timing with light, tan wire unplugged, timing way off and mark knowhere to be seen.
6) Remove dissy and again find TDC manually
7) Turn rotor 180 degrees and reintall dissy
8) Try to start, no start (didn't think it would but had to try)
9) Remove dissy, again set TDC manually on compression stroke
10) Install dissy with rotor facing #1 plug tower
11) Truck no start
I'm out of ideas!
