skipztt
boost
i feel stupid for asking this..lol.
i found tdc on the motor. im pretty sure my balancer is good. so i turn the ty on it cranks over a few times then it, fires up.
now my question is, at idle do i set the timing at 0* at idle? that would be the middle "tooth" on the balancer tab, correct??
or should i set the timing like that, when reving a certain rpm???
i had it running and i set the timing at 0* at idle. now if i advance (well i think im avancing it..lol) the timing making the line on my balancer go counterclockwise/upwards, it runs alot better at idle.
now if i retard the timing at idle, it wants to die. so im assuming what i was doing is right.
im just making sure i get the timing right. cause i want to drive it
oh yeah i have the brown wire disconnected too.
