MYYellowTY
Ok, Ive ordered my Piston stop to find TDC for sure because I had a odd squeek which turned out to be the dist. bushing.So I replaced it and adjusted the valves so I could be sure it was on Compression stroke for timing mark.Dist. is in its running but I have DM going and it says 22.5 degrees spark advance with it idling.It also is timed at 0 but when I connect the brown wire it still is at 0.This isnt right is it??How much should it be for base advanced and total advance??? My main problem is 18* KR in park also at 3500rpm.Iv looked all over and tightened damn near everything.Does it sound like the ECM is acting up.Or the ign. module???Im puzzled!!! :roll: Please help!!!Thanks!!!
