Timing vs boost
Dan B
Junior Member
I posted on tt's support forum about running higher octane (95) with an otherwise stock setup.. Eric wad kind enough to respond promptly saying he would add timing if staying with 2 bar or increase boost if changing to 3 bar.. curious your thoughts on what would be better.
2500avalanche
Well-known member
Hello, So I would go with 3 bar in this scenerio. I run a basically stock set up, slightly upgraded. I had success with a 3 bar map and not going wild with my set up
BMFB
Not to scale
more timing doesn't mean more power, its just offsetting a slower flame with a slower burning fuel. More boost is more air is more power. You tunnin?
Dan B
Junior Member
Figured timing would make it quicker not necessarily faster.. no tuning for me kind of a set and forget it guy.. will however monitor kr
BMFB
Not to scale
more power is quicker. Ive been out of the game for a while, so things could have come along that i am not aware of, but last I knew a 3bar isnt possible without rescaling the fueling tables.
All sensors on this bitch operate on a 5v signal, map included. Means that 0V comes to represent max vaccuum, 2.5V represents atmosphere pressure, and 5v is 15psi of boost. A 3bar means 0V=max vacuum 2.5V=7PSish and 5V=31PSI. Without rescaling the tables that reference that voltage it will not run.
The table ends at 14.7boosties stock, and you can push it a little past that if your feisty, but it will be leaner the farther you go, and in the long run isnt a great way to do it.
To rerespond to your original post id say leave it alone if you are running a higher octane fuel. The timing wont be effected enough to matter, but you will get the benefits of a fuel that wont precombust. This would be advantageous if you are doing a lot of runs in a day and the intercooler gets heat soaked. You could possibly gain power with a diztwist, but it would be under 10hp of gains. Global timing changes dont jive well with this system, as the changes effect regular driving and starting too.
