timming chain
sean
if money was not a problem what is the best double chain you can get for our engines? part# I went on summitracing.com and seen a bunch of them. can any one give advise? and also timming cover
myclone
sean
Re: timming chain
i seen that they make a timming belt is it worth buying? is it better than the chain? has anyone ever tried using the belt instead of the chain? just wondering
myclone
Re: timming chain
No one that I know of makes a belt drive for the factory style roller cam. I think waller runs a belt drive on one of his motors but he had comp cams custom make a roller cam with the flat tappet style front snout to do so (not cheap).
To answer your question belt drives are better than chains for a lot of reasons as long as youve got the extra $$$ to spend.
jwaller
Evil Genius/SyTy Guru
Re: timming chain
dave is correct. the stock style cams will not work with any of the available belt drive systems, comp or jesel or otherwise.
and take mikes advise, I use lots of the edelbrock sets and they do wonderful for much less than a comp or like style chain.
myclone
Re: timming chain
sean said:
does anyone know if the cloye 220-9-3700 is double roller?
It looks to be but since jegs lists it for 1955-95 engines Id make sure it will fit the factory styled roller cam bolt pattern since its smaller than the early SBC bolt pattern. Cam sprocket bolt pattern changed in 87 Im pretty sure.
scotts4
ADDICTED
Re: timming chain
That is the one i just put in my motor it fit really nice . I would go with that one but its cost about $80.00
kessler
Re: timming chain
Sorry to intrude but has anyone used or done a Gear drive timming set for our trucks, Or do they make one for the SYTY
scotts4
ADDICTED
Re: timming chain
Gear drives make to much noise for fuel injected motors with knock sensores it sets them off .
Deanzsyclone
Re: timming chain
I was watching Horspower TV this morning on speedvision and they had a kit to change the chain out to a belt driven system. Don't know if they have it for our v6s.
scotts4
ADDICTED
Re: timming chain
i saw that today too
sean
Re: timming chain
how good are the belts over the chain? how often would you have to change the belt
jjorgensen52
NHSTE - I'm the only one!
Re: timming chain
I think you'd have to change about as often as a fan belt... personally I like the chains better, don't think I like the idea of belts slipping on my valvetrain... I went double roller, I believe it's a comp part but havent got the receipt at hand
