martygar8
syclone #1322
well been having sy issues, so decided to check the fuel pressure and its at 50lbs on idle and up to 60lbs, when accelerated, they tell me the pressure should be alot lower then that, my knock count is crazy, and missing bad, well this is what ive done, changed the cap rotor,wires, plugs 02 sensor, map sensor, upper intake gasket, vacuum hoses, any ideas, next step is check the compression, and if that ok i will change the lower intake gasket and, thinking its vaccum leak somewhere. well its driving up the wall trying to figure this out, any ideas
