93 typhoon
Is there any one that can help me with this info that i am going to put down this is what my truck is doing. wan't to know how can i fix it.
HEI Shielding. An open ignition ground CKT 453 may result in EMI, or induced electrical noise. The ECM looks at this noise as reference pulses. The additional pulses result in a higher then actual engine speed signal. The ECM then delivers too much fuel, causing system to go rich. Engine tachometer will also show higher then actual engine speed.
hop some one can help me
thanks every one.
thanks every one.
