I am new to SyTy's, which I just found out about a couple days ago, and I'm in love. But I have TONS of questions that I can't find answers to anywhere else.
First of all, what set up would I need in a Typhoon to do 12's @ 100 or more, under 20psi? This is going to be a dailt driver but I want it to beat all my friends talons to do 12's. I want to get the most power out of the psi I set it at. Can the stock turbo handle that? How many psi is the stock turbo set at?
I also have transmission questions but didn't want to start another thread.
Can the stock transmission handle the goals I want? They're not too high, but according to wikipedia, the stock transmission can take only 360 ft/lbs of torque but that's stock. The 4L80 seems like a good swap but I like the ratios of the 4L60 because of the higher 4th gear and lower 1st gear. Is there like a 4Hi and 4Lo system or is it just one set of gears with D and OD.
What kind of clutch would I need? Again, could the stock one take it?
Last, what is SGT? I've looked it up and can't find anything...
Thanks and sorry for all the noob questions.
