too much boost
Osmosis
I recenlty got my moates G1 adapter working with the ultimate bins. I replaced my power steering pump....and I dont' ever want to do that again! I also broke the nipple on my sensor that was on top of my turbo. I was able to hook up the vacume line to the larger port, but I think that sensor is bad now. Now, I'm running 25psi and I hear knock. I put my stock chip back in and have not ran it, however, I think the sensor is bad now.
Any thoughts?
No codes either.
Re: too much boost
Any thoughts?
No codes either.
Yeah that is boost control solenoid, they are less than $20 from GM. You can run a vacuum line from the Turbo nipple straight to the wastegate actuator in the mean time (it will be ablout 8-9 psi) to prevent overboost.
