Top end question. Heads, Cam, Chip
TYTILIDIE
METH HEAD
So, Ive decided to beef up the bottom end a bit. I am planning on using Eagle H-Beam rods, Sealed Power Forged pistons and a stock crank. So, my long teerm plans are to take the stock turbo as far as she can go. What I m after is head,cam and chip info. If I went to a Vortec or L35 head what cam would I want to run or should I stick with the stock cam. Also, If I run different heads, will I need a new chip? Can I get the Ultimate and pretty much do whatever I want to Cam wise? I really want to max out the stock turbo by the end of the summer. After that I want to upgrade turbos. Not sure which one I will get to that later. Point is, I dont want to tear down the moptor when I do my turbo swap so am looking for a sort vast so to speak build that will work out well for what I am about to do. Any help is appreciated as always.
