im rebuilding my syclone and was wondering if anyone had to file the rings to fit? they are non file to fit, but i just want to make sure if i have to shave off a little on the top ring.
thanks
You will need to check the End Gap with feller guages. You also need to check the ring in the bore it will finally live in. As each cylinder can be slightly different. (.001 in bore dia = .00314 in change of end gap)
