Daron
http://www.lindertech.com/docs/j_thornton_toyota_wraf_sensor.pdf
"Toyota's air:fuel sensor has the ability to measure
actual air:fuel ratios over a wide range (rich to lean).
The sensors voltage output does not indicate rich/lean
switches as a conventional oxygen sensor does. The
air:fuel sensor informs the PCM of the exact air:fuel
ratio (based on exhaust oxygen content).
Not sure if this is the same sensor (Honda) as folks are using for the DIY setup but untill now I had yet to see discussion of another major car company employing this strategy besides honda.
