TPS help, weird problem need the big guys here
syntax
So i finally get my tps adjusted to 100% using the careful metho of cuttingd and crimping washers around the cable, now i am getting 1005 but with some really wierd side effects! in order to achieve 100% i had to readj the Tv cable and instead of it ractheting 3 or 4 times like everyone says, mine racthes oncee, then ticee, then 3 times, then like 4 more times almost immediatly, the problem is if i only rathcet it 3 times, the TV cable prevents the truck from getting 100%, but if i ratchet it 8 times like it does, it kills the shifts, also at 100% datamaster shows 3.75 Volts for the TPs voltage, i thought it was supposed to be in the 4.00+, am i on a route to a new tps sensor? this problem is bugging the crap outta me, plz help
SyTyJedi
Jedi Council
How are you ratcheting it 8 times?
I'm not familiar with the process of cutting washers - you shouldn't have to do that to get it functioning correctly.
3.75 may be ok at WOT, you just need to have a high value that is corresponding to your low value. I think it only has a range of 3 or so volts. I'm definitely not the expert on the voltage subject, but I do remember if you are getting 100% at the ECM, the volts do not matter.
Ex: .75 at idle and 3.75 at WOT.
This is how I remember it...can someone please post specifics? Was this the solution that everyone decided was correct?
syntax
i wasnt getting 100% bcause my cable was strected, just used the washers to take up the slack, like i said now it rachets 8 times in order to get 100%, thats my problem
jwaller
Evil Genius/SyTy Guru
like he said volts dont matter it's the % that counts. and yuou shouldnt be cutting washers anh stuff like that...sounds like you need another TPS sensor
