tps question?
johne30m3
Junior Member
I have a question about the tps , I was reading that with the truck off an ignition on that on the scanmaster 3 I should read .5 -.8 volts and about 4 volts at wot. Well I'm only getting 3.1 volts wot. Would that mean that my tps is bad? I'm still new to the scan tool so I'm still learning, but if I was only getting 3 volts then theres a possibility I'm leaning out up top because I don't have 100% on the tps . I guess I should check my tps and idc to see where there at. The funny thing is I had runs that were great with no kr and then some with just a few degrees of kr. I'm also wondering if I have a bad motor mount thats causing maybe false knock? Well I guess I will install my new tune up parts first and go from there.
Matt
0.5 volts at idle and 5 volts at wot in a perfect world, you should have a ground, 5volt supply and a return, voltage to ECM will vary with tps position
