TPS Sensor help
syty9933
i am having a rough idle, and sometimes inadequette throttle response, where is the TPS sensor and how can i check it? I tried searching but came up with nothing
thanks guys
Re: TPS Sensor help
On the back, rear end, of the throttle shaft. Usually pretty reliable though. Do a search on rough idle and sit back, you'll find plenty of stuff to look at and check.
Re: TPS Sensor help
I was just recently told that if your tps sensor does not say 0% at idle its a problem. Do you have datamaster. If you dont get it. You need it.
syty9933
Re: TPS Sensor help
what should i check to fix my thottle response, sometimes when i hit the gas it does nothing for a second then catchs on and boost launchs seem weak when i start in
graham1524
Well-known member
Re: TPS Sensor help
get a fuel pressure gauge if you dont have one. i know when i got mine it sorted everything out
syty9933
Re: TPS Sensor help
i fixed it , since it dosent reset untill it warms up, i thought well it never ever warms up and thats not good, so i swaped out the 160 for the 180 and instead of it heating up to less than quarter up the gauge it hit almost half, and it is night time hahaha, and when it hit a good temp it reset and now my throttle response and idle are perfect :woot: it ran so ****ing good . Im so stoked i thought it was an injector or somthing serious. Thanks for the help , now my baby runs and performs so clean and brisk, I am seriously happy, you guys rule
Re: TPS Sensor help
Yeah my truck is a cold blooded animal with my 160 stat in it. I figure it can use the extra cooling with the stock tranny cooler.
