Track Day Video
Gnocide
turbo game burt reynolds
Re: Track Day Video
I ran 7.943 @ 88.39 in the 1/8. 1.76 60'
Also, I experimented with the launches tonight. I was able to build 8psi on the 2step set at 3k. Thats the most it'll build at 3k. Spun a bit at 8psi, so I lowered the rear tires to 25psi and kept the front at 30psi. Tryed again, and got a little more than a chirp. I also tried just launching on converter at 10-11psi and that was violent.
So I'm guna try and adjust the 2step to 3200rpm for more boost, and adjusting the limiters lower.
your 1.7 is good.
question. what was the time and mph on 11psi run?
you have a built tranny and convertor so
why is 3k+ where you wanna leave instead of say 15+psi?
you should be wanting to leave with as much boost as possible
every single time unless you can spin the tires through the 60 foot mark.
Sean Krupa
Moderator
Re: Track Day Video
I did the above in an industrial spot for testing purposes, no track time. I was practicing my launches. The point of me getting the 2step was for more consistent launches and not looking at the boost gauge and the tree at the same time. If I set it at 8,000 rpms I'd know how much boost I'd make at, so I'd know ahead of time, and just focus on the tree.
Also I'd try not to launch at 15psi+ just for the fact that I'm not breaking a world record, I just want a good ET and my goal. Also at that boost, something would give sooner than later.
Ya I have a built trans, which took me a year to piece together due to my young age and funds. So if I have to launch at 30+psi just to get my goal, then it isn't worth it to me to break something in the process. Just my :2cents:
I appreciate the tips and advise!!
