ls1monza
Got me UNDER PRESSURE!!
Re: Trailblazer SS rapage
I see nothing wrong with what you said. Your truck is obviously fatser than a low 14....I would suppose the gauges up his pillar were for looks. Honestly, I have never seen a 4wd one and would assume they are much slower considering they have the same motor and much more weight. When I first got my truck and logged it; there was a tremendous amount of KR...Alot!!! It seemed to populate a load area which was not efficient at all... If the sudden need to pass someone came and you rolled into the throttle(and it pulled 15 degrees of timing) the truck went nowhere and was exactly like most of you describe. Even after tuning mine; it still was impossible to remove all of the KR. The truck is just too heavy for the engine to pull through at such low R'sPM. UNTIL......By installing a very streetable smallish stall converter,it fixed all of that. It was the single,best improvement I did. It's worth 8-9 tenths by itself(well...tune also which needs to be done to adjust lockup speeds and shift points to accomodate the new converter) Now the timing never goes into those areas...converter prevents it. So...to recap. Everything else stock/ most likely same hp as bone stock(add some from tune which is lost from converter)....A 13.3 @ 102mph would be average in Texas...Install headers,air filter and pulley; you have my average truck which runs mid 12's. I am stating this as a matter of opinion based on fact from personal experience and in no way trying to boast or brag about the benefits of selling a typhoon and buying a Trail Blazer.
