Trans and oil cooler question
jjorgensen52
NHSTE - I'm the only one!
Has anyone heard of / done this? I'm considering, when I get my new trans, installing a heavy duty trans cooler ahead of the radiator and eliminating the use of the stock trans cooler altogether, then routing the oil lines through it so I have dual oil coolers in the radiator with the trans cooler in front. Switching to electric fans on the radiator as well.
Jer
Don't taze me bro!
Re: Trans and oil cooler question
You could do this... extra capacity would also be nice. I chose to go with a larger aftermarket coolet and a 600cfm fan in front of it. Haven't yet had a chance to run launches in the dead of summer heat to see how it reacts but I'm sure it'll be much better than the factory setup.
jjorgensen52
Cooler on the trans or the oil?
Tommyquest
The Member's Member
I run aftermarket coolers. My BeCool rad. didn't come with a engine oil cooler. For the trans I run it through the radiator first then through the aux. Tranny temps never go above 150, ever.
sy2185
hey Tom,
Are you saying 150F at the sending unit in your manifold just before the rad? And that's coming directly out of your trans? What type of conv./setup you running?
Jeremy
SY2185
Tommyquest
The Member's Member
Yes, fluid is 150 coming out of the tranny before it hits any coolers. I run a 2800 PI converter, 4-bolt, eagles, TRW's, vortechs, PT74, 75#'s, RPM IC core w/ Nolan's pipes, Razor alky, Nolan's chip. I just recently changed to this turbo from a T-72 q-trim single BB. I'm going to have the converter restalled as it's sluggish with the 74. I project it will run a little hotter with more stall.
Jer
Don't taze me bro!
Here's a look at what I did. Kind of hard to see but it's behind the front mount intercooler there.
jjorgensen52
Looks like you have no a/c in there Jer. I'm aiming to keep the a/c and go to front mount A/A, so what i'm looking at is using the two in radiator coolers for the oil and then running a perma-cool 1250cfm trans cooler over where my abs block used to be since the nose is pretty much full... close, but it'll fit.
