Trans cooling lines
caci
Where do you "clock" the 45 degree fittings for braided steel 6AN trans cooling lines. My engine is out, with the trans is sitting a little low and I can't visualize what looks like a good position for the lines that will route forward to a front mounted cooler.
Thanks,
Chris
TYHOGG
Re: Trans cooling lines
With out crawling under my truck, i believe i pointed mine towards the bell housing (almost parallel with the ground). If that helps any.
EcSy#2671
Si vis pacem, para bellum
+1
