Trans Removal
SY2932
Administrator
Re: Trans Removal
I had trans mount snap. Bolt was loose a year ago went to tighten and it snapped right off. Same thing happend 2 days ago. These bolts are threaded all the way through the adapter plate 4x4 (2 fastners)
I would just drill them out and chase the threads if necessary:
I'm guessing that you don't have vertical mill at your disposal though. You can use easy outs, sometimes you get lucky and the left hand drill bits will back the broken fastener out.
Darin
Re: Trans Removal
If it's aluminum, a little heat goes a LONG way with an easy out. Another method that I've used in the past many time for removing busted exhaust manifold studs out of 4G63T heads is to grab a welder (TIG or MIG) and weld a washer onto the broken stud so that it's laying flat, and you "fill" the hole in the washer with weld. Make sure not to hit the material, just the stud with the weld. Then weld a nut onto that whole contraption. It'll usually just turn out easily at that point.
I've done this with old rusty SBC heads as well, worked well!
Re: Trans Removal
I'm surprised the bolts broke. but... If the hole is clear through some heat on the alum as mentioned wil do the trick. Just need a way to turn the piece. If it wasn't alum heat the bolt quite a bit, let it cool then it should come out fairly easy. If you can find this stuff it's 10 times better then any over-the-counter product I've used.
https://www.partsmaster.us/SitePages/Products.aspx?Code=040403
Check this thread for more ideas:
http://www.syty.net/forums/showthread.php?t=92269&highlight=blaster
Slyclone
Well-known member
Re: Trans Removal
After many moons ( 3-4+ years?) I decided to pick back up where I left off. In the coming weeks I will be moving forward with the rebuild of transmission. Only took that long right?
Using my original transmission out of tuck. Most likely going with a 700r4l60e.com kit from Dana ( pro built automatics).
Any tips/input/advise is welcome.
Syc0914
Re: Trans Removal
I had to Pro Elite kit installed last fall from Pro Built and couldn't be happier with it. I used a PTC 2800 converter and the combo works well IMHO. Have only put a few hundred miles on it but the kit has been used by a few people on the forum. Good luck with the project!
Slyclone
Well-known member
Re: Trans Removal
Ok great, thanks for the imput. Was told to go with the pro eliete kit as well but I'm in between the autocross kit ( road racing) and the pro street kit. Has anyone used either of those two kits?
