B
BoostedGMC
Guest
I am going to be buying a transmission temperature gauge and need a spot to put the sender. I have decided to go with an aux cooler and ditch the cooler in the radiator setup.
I think I will be buying a b&m cooler from jegs #130-70273 ------> http://www.jegs.com/p/B-M/B-M-SuperCooler-Transmission-Cooler/758370/10002/-1
I need to know what size an fittings I will need to go from the trans to the cooler and back.
I will need some kind of fitting where I can T into the inlet of the cooler so I can put the temp sender in.
