Transmission Advice
Slyclone
Well-known member
Looking for some one to give me some pointers on the trans. Went to a shop and guy pulled pan. Saw metal shavings. things didnt look to good. I have new Tq converter to be installed and he telling me needs whole rebuild.
Wondering what outside parties are asking for a trans done.
BoostedSUV
Re: Transmission Advice
Cost me $2000 to get mine rebuilt and beefed up to handle more power. Be careful going to a standard trans shop, there are a lot of specific parts only found in our transmissions.
Mobile22
SY#1819
Ask around to see who the best transmission shop in town is and you'll find that most people will point you to the same place. Take it to them and tell them you need to have them crack it open and fix only what's broken. You should have a corvette servo and high performance clutch packs that are stock. It's not just a 700r4 transmission.
I paid 1600 for a quality rebuild. What he took out he put the same or better back in and gave me a lifetime warranty. They guy couldn't believe it was the factory transmission because of the parts that were in it.
And make sure to check or replace the transfer case fluid and the front diff fluid. They won't touch it unless you ask.
Slyclone
Well-known member
Heres the story. Guy is a pretty good friend. Runs a trans shop. I took truck to him only to get a price on converter install. He starts telling me that the fluid smells burnt. Lets check it out. He cracks open the lower pan. shows me a magnet encased with metal shavings.
I determined that the inside clutch plates are wearing
He starts going on about type 6.saying it is a type 6 ? Talks about servos. I told him I was advised to stay away from all that- Not to long ago I put a post up about "shift kits"- got my answer than.
So that being said. He is talking about Blue racing clutch disc or plates (Never heard or seen them) told me they are way better. Drilling out the front pump? or I will blow the seal? Using full synthetic ATF..$$..
So I was given a price of 1750 with regular clutch plates or w.e and 1850 with the "blue" ones. He really emphasized the blue ones.
To add. He dranied all the fluids. re filled it. I was on my ride home and the truck started to shutter. I felt wheel vibrate. seems like something is seriously wrong after a simple checkout- My dad said it could be the new fluid on the plates they could be glazed. I am not sure but ... all the sudden its shuddering and vibrate
Ty 1885
Some stuff (tiny metal shavings, small amount of clutch material is normal on the magnet).
What fluid did he put in? How many miles on the tranny? When was the last time the tranny fluid been changed? Was it shifting good before the fluid change?
If a tranny fluid have not been changed for 100,000 milesor more, DONT change it! Auto or standard.
What happens when the tranny fluid gets old, it losses its detergents, friction modifiers ext. When you change the fluid, the new fluid washes the old clutches with high amount of detergents and it starts to slip.
cloneman315
All the syty trans story's start with.i know a guy that said he can fix my trans,few weeks later boom!!
Slyclone
Well-known member
Thanks for all the input at this point.
Trans fluid was standard red stuff. Dextron Mercon Tranny has 84k on it. No history of rebuild or any documents I have, But The guy who looked at it told me it was opened/drained and cleaned before. There were finger swipe marks inside the pan.
I checked the fluid level 2x before I left. And truck produced the vibration as I was pulling out. rechecked at home and it was spot on.
The vibration is getting WORSE. Trans seems like its completely wiped out. (driving my truck with a bad ass look on my face) :steamer: Tonite truck just vibrated around 40 . No need to continue to see if its going to vibrate harder. It never did before
Slyclone
Well-known member
Prop shaft? eh... now what thats ready to let loose? I wish I had a camera that I could setup to observe the movments and noises. Funny how this just dominoed from 1 thing to now 3. count the prop shaft 4. Either way if I buy a new refurnished unit,(trans) Im still upagainst a removal and install of the drivetrain.
It all seems possible it my eyes. All the weak links are going.
About the prop shaft. I remember I had the front portion loose and hanging. I could not remove the back part off the T case for some reason. I cant remember why. Maby something with the hardware and access.
neildemo
Administrator
Call them they are the best for syty transmission and shipping is really easy and reasonable. I have made the mistake of taking a tranny to most reputable local shop save yourself the headache and call rpm.
I wouldnt say the best one of the Best. Rossler Transmissions are king in my book.
neildemo
Administrator
Listen to Dave he has never steared me wrong and he is 10 for 10! His knowledge and Experience is second to none. Good luck.
Ty 1885
^^Transmissions don't do this^^.
They can slip, but they won't shake the steering wheel. Perhaps slippage will cause a vibration, but the vibration will stop when you let off the gas. Does the vibration stop when you let off the gas? Is the frequency of the vibration associated with road speed or engine speed? If changing the engine RPM doesn't affect the frequency or severity of the vibration, it can NOT be the transmission.
You're about to fook yourself into a transmission rebuild that can be put off for awhile. A certain type of debris in the pan (a grey 'dust' that clings to the magnet, and you can write in with your finger) is normal converter clutch wear. If there's no chunks, or bronze in the pan, and it's working correctly, there's nothing wrong with the transmission.
I'll write it again: The vibration you're describing is most likely a front driveshaft vibration. Actually, the front joint in the front drive shaft. Take it out (no excuses about "can't remember why it won't come out") and go for a drive.
I have SyTy bucks that it's not the transmission. BWTFDIK?
2X:tup:
ranger
Hi folks,
Is not John Waller still the "best"?
I thought that he was the only one who has guys with our tranny dipping into the 10-second quarter mile??
Best,
Ranger
Aiken, SC
Seems like every few years, there's a different "best" trans guy around here. For a while, everyone backed Waller. Then it was Blake. Now it's RPM Trans.
