IGottaSy
Re: Transmission is out today, finally!
[/URL][/IMG]
Fired it up today... pressures tv cable off...at idle
park 90 psi
Reverse 150psi
forward gears 298psi
Seemed a bit high so yanked on tv cable but no change. Goes back to same readings. Pulling on tv cable works as expected, though. Emailed the shop about it and will wait until they reply. Ran through the gears leaving drive shaft and prop shaft out for now.
Fluid level is OK when in drive but shows 1 pint over when back to park... weird.
Syclone 4L60 shop test: http://youtu.be/yxloRzD_XFo
park 90 psi
Reverse 150psi
