Transmission slipping
or what??
Look at this DM file and look at 2 parameters, speed and RPM.
https://dl.dropbox.com/u/86797850/AutoLog_341.uni
If I understand the first RPM ramp is the truck accelerating on the TC then lockup. Second ramp is 1st gear, 3rd ramp which is nearly flat is 2nd gear, then the RPMs drop while the truck continues to accelerate. Then, around record 186, it's 3rd gear the rest of the way.
Now when the truck makes the, presumed, 2-3 shift it's not like the TC lockup or the 1-2 shift which are hard. Its as if something is slipping and the RPM and the truck have to sort-of play catch-up before I feel one more, softer, shift/lockup (I'm not sure which) at record 186.
It seems to me that each shift should be the same.
So my question is, is this normal? What's going on? I don't have x-ray vision but I don't think I'm hurting anything only because it seems to be the same every time. Then again....
Thanks all.
Big Mike
Re: Transmission slipping
I had used lock up on my truck at the track and it only took 6 runs of locking up the converter before the truck tore up the lock up clutch inside the converter and got through the trans what a mess everything trans related has to come apart to get cleaned out. Pull your trans pan and look for clutch material. if this did happen I suggest going to a trans shop to get your lines and cooler flushed out. Also you will be pulling the trans to get it taken apart and cleaned out too. Your converter will need to get rebuilt or replaced also. After all that mess I was told by trans guy to lock up in 3rd gear only at track, it still tears the lock up clutch up but should last longer.
