trip odometer, doesn't work. anyone have a fix?
B
blast
Guest
ever since i bought my truck the trip odometer hasn't worked. when you clear it, it works for about 1/2 mile then stops. anyone know how to fix it?
thanx
rob
phoonTy
Truckless. For now.
i'd also like to know if it can be fixed. mine works, but only registers half the distance you've driven...on a good day.
B
blast
Guest
looks like i'm not the only one who would like to get this fixed. hopefully someone will post here how to fix it.
rob
4C FED
Absolutum Dominium
mine goes forwards, stops, then goes backwards. No I am not kidding.
I think it has to do with the DRAC. That small little piggyback box on the ECM. Or whatever the heck that thing is.
ericguy320
Stupid Member
wow i dont feel alone mine gose to .9 then stops i think i am goin to send it out and see if it cant be fixed.
jwaller
Evil Genius/SyTy Guru
sounds like you guys need the small elec motor that powers the trip odometer....to bad I only have 1 left...
let the bidding begin.. :eek:
bdubb
I am teh kingpin!
two dollar
ed hess
race or get outta the way
Ill give ya 5 bucks plus the tits in the post above. roflmao :D :D :D
ya know for some reason that gif plays continuosly on my laptop....wish i could make it do the same on this machine.
ed
typhoonzz
Got Boost?
I have that problem every once in a while
Usually hitting the rest will fix it
If that doesn't a good whack on the dash with your fist usually does :banghead:
jwaller
both the tripodometer and odmeter are actually turned over by small elec motors. these motors are not interchangable between the two. and they both have a 3 wire connector that is detachable inside the cluster for easy removal/detachment if you catch my drift.
