trouble building vacuum
#2875
built, not bought
with this new build i am having trouble getting even 10" of vacuum at idle. boost leak test turned up nothing (probably because the vacuum lines are all new), timing set with light. i have the 412 cam, vortec heads. any ideas?
#2875
built, not bought
Re: trouble building vacuum
incorrect valve timing is possible, i didn't degree the cam or anything. plugged exhaust is definately not possible. how long does it take for the rings to seat?
#2875
built, not bought
holy shit thats a long time. no i broke it in with synthetic because i couldn't find any objections about that when i did a search. should i have used dino?
With a cam vac can be low. Does it idle ok? Run ok otherwise? Build boost? I could go on. Rings, IMO aren’t going to make much dif. If you want to go to the trouble of a compression/leakdown test a weak cyl might but I think you’d see other probs.
What’s idle speed? How's throttle response? Sorry but when you did the timing did you disconnect the wire under the dash?
I Would Have Used Dino...buts It's Too Late Now...don't Know..like Don Said Could Be Several Diff Issues..do U Live Near Any Experienced Sy/ty Guys... Maybe They Could Look At It For U...???
canadian
sy in progress
First question is how you're measuring it (stock gauge, aftermarket gauge?) and where is the source?
#2875
built, not bought
idle speed was about 825-875. yes i did disconnect wire when timing. source is manifold, not FPR but the other one. i have no egr, vball or canister so the only other things on the line are cruise and climate. it idles fine and revs quick. i realize there should be less vacuum with the new cam but 9-10" seems low. still stumped.
#2875
built, not bought
aftermarket gauge seems to correspond to scan tool. yes, 3 bar. haven't looked at stock gauge since 1805.
#2875
built, not bought
ultimate v9 with stock ecu (obviously). i have a msd box, pte60 turbo. not sure what else is relevant.
another question i have is why does the timing mark jump around a few degrees with the wire unplugged?
I know this sounds wacky but I actuall found my dist. bolt loose! Also lots of folks have said it's a good idea to do a TDC check on the dampener. One other thing, you have to clear the ECM (after setting the timing with the wire disconected) by removing the fuses.
I know this sounds wacky but I actuall found my dist. bolt loose! :eek: So check the dist. itself and make sure it's tight. Also lots of folks have said it's a good idea to do a TDC check on the dampener. One other thing, you have to clear the ECM (after setting the timing with the wire disconected) by removing the fuses.
danny
I'm chasing the same problem as you, I just did the vac test with a bike tube and found my new iac is slowly pissing air. The hiss was hard to hear but it got worse when I wiggled the electrical connector. Seems to be leaking where they joined the plastic to the metal. I need to get a new one tomorrow and hope this cures my problem. It's a shot in the dark but recheck the iac. Will let you know the outcome when I get it back together.
You are probably missing around 8" vacuum, so its going to be a big leak. Is your Intake properly seated against the Vortec heads. How did you do the conversion, double gaskets or rewelded intake? Are you injectors seated properly into the intake, any chance left out an Oring. (Yoou can check the injectors by spraying the potential area with carb cleaner while its running, the engine will speed up if leaking.
#2875
built, not bought
i did a boost leak check and it held pressure pretty well. it held at least as well as it did before i blew the engine when it made 19" of vacuum. injectors are good, the thing runs great (now).. it just has low vacuum.
i am in the process of reinstalling the oil pan because the rod bolts were hitting the bottom of my pan. i'm going to double check tdc with a piston stop too, might even degree the cam if no change. there's only a few things it could be at this point. i'll let you guys know what i find out. i just had acl surgery so give me a bit.
